Summit 31x19" radiator
Old Jun 7, 2006 | 08:42 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Ordered one up and it showed up at my doorstep today. Quality was about what I expected from a $160 piece. Tanks are fairly thick aluminum and the welds are ok. There were some tool marks on the tank and some solder splattered on the fins but nothing that didn't clean up easily. I guess that's the difference between a Summit radiator and a $600 Be Cool.
Install isn't bad so those that are scared, don't be. Dropped the new piece in and fitted the upper support. I used the stocker and trimmed it wherever it hit, mostly on the ends near the tanks since they're so much bigger. I also used a rubber mallet and a dolly to gently bend over the aluminum "ears" at the top and bottom of the radiator. It allowed me to drop it down lower and closer to the stock location and also allowed the stock upper support to fit a little better. I used the stock hoses too, just had to trim about 2" off of the lower hose. The inlet and outlet on the Summit radiator are a little larger diameter so I had to use a squirt of WD40 and some elbow grease to get the stock hoses on, but it wasn't a big deal. Nice and tight. I also had to use a metal hammer and give the frame rails a couple love taps. Right where the radiator support attatches to the frame rails needed to be massaged just a little bit. Without doing that I had to tap the radiator down into place and I didn't like that.
As for fans I used two 12" units I picked up off of ebay and just used the push-in fasteners to secure them in place. I have the material to make a nice shroud but didn't feel like making it so that's another project for later. I wasn't having any cooling issues before with the stock radiator and fan so I think I'll be just fine with this big rad and twice as much air moving over it with the different fans.
Old Jun 9, 2006 | 01:09 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Got any pics?
Old Jun 9, 2006 | 02:25 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
thats EXACTLY what i did with mine...i never got it to fit under the upper rad support..and had to custom make a fan shroud...that i now removed using aftermarket fan...basically my setup wont run over 180 in any situation...the rad WORKS awesome...screw 600 bucks for high price name brands your just paying for the name
Old Jun 9, 2006 | 08:35 PM
Dialed_In's Avatar
When you pay $600, you get a little better quality but I couldn't justify the $$$.
I had to do quite a bit of trimming to get the upper support to work and with twin fans there's not much need for a shroud.
Old Jun 11, 2006 | 09:57 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Dialed_in, Will the stock twin fan set-up not go back on? Or did you just want better fans? I want to get this rad too. Thanks.
Old Jun 11, 2006 | 10:26 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
What's the Summit part number?
Old Jun 13, 2006 | 10:08 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Any pix of the install?
Does the rad displace or move the fans further toward the motor... W/my procharger I only have about 1/4 in from the factory fans and the upper rad hose is about the same from the belt on the procharger...
Ryan
Old Jun 14, 2006 | 07:56 AM
Dialed_In's Avatar
The radiator is a little closer to the motor, but with the aftermarket fans being thinner than the stock electric you acturally gain some room under there. I'm sure you'd have no problem.
sheachopper
Jul 31, 2019 11:27 AM
school boy
Oct 22, 2015 11:47 AM
