recharging a/c..need help asap
Old Jun 17, 2006 | 02:30 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
hey guys, i have an 89 trans am (305 tpi) and I am about to add some r-12 and i just want to make sure which is the low pressure side? Both fittings are the same size unlike r134 systems, and I don't want to have any problems.. thanks
Old Jun 17, 2006 | 02:57 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the low side is on the accumulator
Old Jun 18, 2006 | 01:42 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
thanks man
Old Jun 18, 2006 | 02:07 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
woah where did u get the R12 from and how much did it cost???
Old Jun 18, 2006 | 06:39 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
i found a local guy selling 2 cans of it for 20 bucks each on craigslist so i snatched em asap! i do have a new problem now though.. as we were adding the r-12 (the compressor kept engaging and disengaging) ..the compressor started staying engaged a few seconds longer than normal and then the compressor started to smoke slightly so I shut the car off right away.. my dad said that it looked like maybe the ac clutch was getting stuck or something (he also said it sounded like it was rattling) … sooo anyone know if my compressor is bad or just my ac clutch?
Old Jun 19, 2006 | 01:19 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Dude that sucks. Your compressors seized. Sometimes happens when a system becomes saturated with moisture or just old... You need info on a retro fit let me know. be sure now when you do everything (compressor) Replace the accumulator, orifice filter, flush the system than install everything. Good luck
Old Jun 19, 2006 | 10:23 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
When the system has only a little pressure (~15 psi) the compressor will engage, and then dis-engage often as the low pressure enable switch opens and then closes. This is normal and caused by the pressure change as the compressor pumps up.
The temporary solution is to disconnect the low pressure wire plug from the switch, and then short across the two pins with a paper clip, this will make the compressor run the whole time. While doing this add more freon! Soon there will be enough pressure to allow the system to run the compressor continuously without the paper clip jumper in place. Reconnect the wire plug to test.
Top it off with about 35-40 psi while running.
86White_T/A305
Mar 6, 2016 01:48 PM
92projectcamaro
Sep 24, 2015 08:09 AM
Johnoooooo
Sep 22, 2015 08:55 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Formula_88AE
Sep 3, 2015 01:47 PM
