fans not working, did search
Old Jun 19, 2006 | 10:13 AM
PAformula's Avatar
'88 GTA 305 TPI, 5-spd with dual fans. We overheated it last nite, after driving it for the first time since putting it back together. We were idling in a parking lot when luckily were heard the beep from the digital dash which made me look at the dash and see the temp maxed out. we shut it off & poped the hood, coolant was boiling over to the resevior. The fan never kicked on. We order a relay yesterday, but there are 2 relays for the fans. Which relay controls which fan? Also, if that isn't the problem, what else should I check? temp. switch or sender. Which one controls the fans?
Old Jun 19, 2006 | 09:19 PM
PAformula's Avatar
replaced relay next to radiator on pass. side ~ no change.
Ran direct power to left fan motor from battery, fan does work. Left is primary correct??
Old Jun 20, 2006 | 04:57 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
Driver side is primary and passenger is secondary. On my 91, there are three relays up by the brake master cylinder. One for each fan and the fuel pump. IIRC while facing the relays, the middle & left relay are the fan relays (but that's from memory).
Old Jun 20, 2006 | 05:23 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
The 1992 tpi's have three relays also. The middle is for the fuel relay. The fuel relay will have 5 wires running out of the bottom. The other relays on the left and right will have only 4 wires.
The fan switch is located in the passenger side head by the #6 and #8 spark plugs.
plenty of material on fan switches in the forum.
Old Jun 21, 2006 | 07:23 AM
PAformula's Avatar
Thanks for the info. I was told that Haynes manual lists the fan relays as being next to the radiator on the core support passenger side. Are the camaros different than the firebirds?
Old Jun 21, 2006 | 07:26 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Not that I know of, my 86 firebird base car had the relays on the firewall as well.
Old Jun 22, 2006 | 10:26 AM
PAformula's Avatar
I think GM must have located them in 2 places then. This GTA has it placed on the core support and pass. fender by the canister. Anyway, I think my problem is the connector or wire running to the cooling fan switch on the pass. side head. The outside of the connector body is burned from heat from the manifold. Grounding the connector with the key on should activate the fan right? well its not. Has anyone replaced their connector/pigtail?
Old Jun 22, 2006 | 03:33 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
I had the problem with my fan switch connector, still the original, came apart in my hands. I got a new one from TPIparts (one of the sponsors). It came with crimp (sp?) connector on it. You can use it like that if you want, but I'm kind of old school and removed the connector and soldered the wires and used heat shrink around the connection. Now when I ground the connector the secondary fan comes on.
Old Jun 22, 2006 | 10:33 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The Primary relay Is on the Firewall near Master cylinder the other 2 are MAF burnoff relay and fuel pump relay.
The relay near the radiator is for the secondary fan. At least on my 89 Iroc TPI.
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
kyle5647
Aug 15, 2015 11:56 PM
Leggman1
Aug 6, 2015 04:15 AM
