Will A/C compressor clutch kick on if nothing in a/c system.
Old Jul 18, 2006 | 08:33 PM
Firebat's Avatar
Will the A/c compressor clutch get +12V if there is nothing in the system. Will the low pressure switch cause it not to turn on? I am getting ready to add freon. I have swapped in a LT1 and don't know if the A/C is supposed to act this way or if I have a wire/ground disconnected somewhere.
Old Jul 18, 2006 | 08:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
correct, unless the low pressure switch is broken, it won't turn on.
Old Jul 18, 2006 | 08:53 PM
Firebat's Avatar
would it be bad if it wasn't wired right and i tried to add the cans of 134a in? While the engine is running
Old Jul 18, 2006 | 09:29 PM
Toehead's Avatar
Watch the pressure while you are putting it in... The compressor should kick on for a second when the pressure in the low side reaches about 25psi. If you get it up to about 45 and it still hasnt kicked on, suspect the wiring. Another way to ry the wiring is to jumper the switch connector with a wire.
Old Jul 18, 2006 | 09:31 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
no it will not hurt the compressure as long as you put the 134a as a vaper on the low side.
Old Jul 18, 2006 | 10:31 PM
Toehead's Avatar
happy birthday BTW
junior419
Apr 7, 2025 11:35 AM
Mdenz3
Sep 17, 2015 08:36 AM
Ironhead38
Sep 7, 2015 02:26 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
