Can't find vac line for heater control valve
This is on the 86 T/A. I know where it is on my 92 but the 92 might be different. I did an engine swap on the T/A and now can't find it and I want to add a heater control valve. Where should I be looking?
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
It should still be coming out of the HVAC wiring harness under the hood. Just like on the 92. Someone might have broken it off.
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
sounds like someone did some chopping before you bought the car?? You should have a diverter valve on your heater hoses with a return line to your intake manifold. You should also have a vacuum line from the divertor valve going somewhere in your harness back behind the coil pack very close to the firewall.
Axle/Gears: 9-bolt/3.45
Follow that skillfully drawn red arrow, lol.
The vacuum tube comes out of that pack to the left of the heater hose connections at the firewall.
The vacuum tube comes out of that pack to the left of the heater hose connections at the firewall. Thread
The_Phoenix
Feb 4, 2016 07:10 AM
