any other stock radiators fit?
Old Jul 28, 2006 | 11:23 AM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
im afraid the stock radiator in my 84 camaro is struggling to keep up with my new motor, and i dont really feel like spending hundreds of dollars on a new aluminum onee. is there a radiator from any other car or truck that will fit?
basically it would have to have the same size inlet and outlet, and the same height, but be thicker and/or wider. anyone have any ideas?
Old Jul 28, 2006 | 12:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
good luck, i been looking for years and have been across a billion different makes models years and havent found anything close except s-10 ones but they arent exactly right either
a good used one after mail cost is at least half the cost of a brand new one, its really pretyt much more worth it to buy a new one locally at the parts store
o reilly auto parts has some real good deals on radiators i just bought a brand new copper brass 3 row for my 84 caprice for 95 bones
thats cheap
good luck
Old Jul 29, 2006 | 05:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using a three-row with GM dual electric fans and experiencing no heating problems.
JamesC
Old Jul 29, 2006 | 07:49 AM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I'll have to double check,but a 4 row from a 91 caprice will fit.All you have to do is if you remove your old rad. look down and you will see that the metal on both sides of the rad. (on the car) have a curve to the inside,take a hammer to them and make them flat and it will slide right in.I will double check with a friend of mine who has done it.
Good luck,
Mike
Old Jul 29, 2006 | 12:07 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Buy a griffen 13x19
180 bucks
Old Jul 29, 2006 | 12:35 PM
Parrydise7's Avatar
I planted an IROC rad in my 1985 Sport Coupe.
Right now it isn't cooling the way it should (or used to), but I just checked the viscous fan clutch and it needs replacing.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
