simple question
Old Aug 2, 2006 | 10:55 AM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
simple question
is there a way i can ground out my electric fans to make sure they are working? Car is overheating and I don't think they are turning on.
Old Aug 2, 2006 | 11:00 AM
j dezzy's Avatar
Car: 87 TA
take the wires and hook them directly to the battery. easiest way.
Old Aug 2, 2006 | 11:04 AM
which wires? I'm familiar with some basic engine stuff, but never really messed with the cooling.
Old Aug 2, 2006 | 12:13 PM
j dezzy's Avatar
Car: 87 TA
the only 2 wires that run into your fan motor. you can cut the wires or just run lead wires off the connectors.
Old Aug 2, 2006 | 05:24 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Isn't there a fuse too?
Old Aug 2, 2006 | 05:29 PM
j dezzy's Avatar
Car: 87 TA
jsut to test the fan right out there is no fuse in the way just straight wires right to the battery to see if the fan runs. but regular setup there is a fuse and a relay.
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
