can i fix my condenser?
Old Aug 3, 2006 | 08:11 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
my condenser is leaking ,i found the spot where is leaking i was wondering can i fix it, a new one is about $ 180 !! any idea let me know thanxs!!!!
Old Aug 3, 2006 | 11:26 PM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
If its leaking from being rotted, id buy another one.
If the leak is a crack/ in the core, yes you can fix it.
You will need 95.5/ or silver, to repair the leak.
Matters were the leak is/ and how big of a leak.
Old Aug 7, 2006 | 03:06 PM
missouraman's Avatar
Car: 1991 trans am
Engine: 5.0l TPI
Transmission: 700 R4 Auto
Axle/Gears: Don't know... DO U!
or u can use jb weld like i did :LMAO:
And it works so don't knock it hehe!
Old Aug 7, 2006 | 06:36 PM
Axle/Gears: 3;42
JBWELD,is pretty kool stuff,ive used it, and many others have,
Matters if you solder, id go that route, if not jb may do it also.
Either way, good luck.
Old Aug 7, 2006 | 07:05 PM
Car: 1991 trans am
Engine: 5.0l TPI
ya i'm saying i wanted a quick fix and it was 10 at night. so in the mornin i was able to charge and go!!
Good luck man either way u go
Old Aug 8, 2006 | 08:52 PM
Car: 92 rs
Engine: 5.0
hey guys forget the condenser it was really corroded so i went to a junkyard and picked one up for $40 i also bought a new acumulator o rings orifice tube , but now i can`t take the acumulator apart the threads are frozen solid and am afraid that if i try to hard i will break the evaporator and just open a can of worms !!! any ideas on how can i take this conections apart???
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
