Heater Core question
Old Aug 5, 2006 | 10:32 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: Built 700r4
Well I'm starting to have a small coolant leak inside the car. I figure its my heater core.
I don't use the heater at all (no more blower motor) so I was wondering since I notice a lot of guys who don't run with a heater dont have the hoses anymore connected from the water pump to the firewall.
Can I just take out the hoses and put caps in both the waterpump and intake manifold?
Doesn't that interfere with the flow of collant?
Old Aug 5, 2006 | 10:46 PM
Stephen's Avatar
Car: 87 GTA
Well, I guess you could. Generally, like mine, we use a bypass. 3/4" to 5/8" adapter, to connect the two heater hose connections together.
Did mine 2 weeks ago. Be sure to blow the water out of the heater core. I didn't, and the water that was in the core, slowly leaks out. Still need to use compressed air to blow out the core.
I bought one, then discovered I still had my old one that I used on my old Camaro, until I replaced the heater core.
Old Aug 5, 2006 | 11:10 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
aren't the two openings a bit close to try and connect a hose to?
Old Aug 5, 2006 | 11:18 PM
Stephen's Avatar
Car: 87 GTA
They are very close. One makes an immediate 90 deg bend down, so that helps the turn to connect them...a bit. Works though. If I wasn't going to replace my heater core, I would pull the hoses off completely, and cap where they connect on the other end. Then, you could get rid of that vacuum swither for the heater hoses.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
