caar runs a little on the hot side
Old Aug 16, 2006 | 10:35 PM
toms86Z28's Avatar
i have an 86 z28. i have a problem with the cooling. with my fan always on the car sits around 230F and when im running down the highway it somtimes get to 260F and when i slow down goes to around 230 to 240. radiator is only 7 or 8 months old water pump about a year. all hoses are new 160F. high flow stat.
Old Aug 17, 2006 | 12:04 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
well since it gets hotter when you are driving I bet your air dam is missing or pretty destroyed. look under the car and the base of the rad core support. is there a black plastic wall sticking down about 6 inches? if not get one. Hawks Third gen sells them for 25 bucks or you could order one through your local dealership.
thats a start. just remember GM designed these to run HOT as in the factory fan switch is around 225-230. and the air dam is needed for staying cool while driving.
Old Aug 17, 2006 | 05:30 PM
toms86Z28's Avatar
theres no air dam there. and the my fan is rigged to stay on. couse i cant find the switch on the block that turns the fan on
Old Aug 17, 2006 | 06:00 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Do you have a dual fan?
Anyhow, if the fan is always running, that wouldn't hurt and should help keep your car at a lower temp.
Get that lower air dam put back in. Check to make sure you're running with full oil, and your coolant levels are topped off.
Also, you can use a "water wetter" additive product in your coolant which will help drop the temp too. But it's not a long term solution.
Old Aug 17, 2006 | 11:39 PM
toms86Z28's Avatar
single fan.all my fluids are full. i got 2 bottles of watter wetter in it. with the fan always on it runs 230 to 240
Old Aug 17, 2006 | 11:40 PM
toms86Z28's Avatar
single fan.all my fluids are full. i got 2 bottles of watter wetter in it. with the fan always on it runs 230 to 240. and im looking for a lower air dam
theshackle
Mar 5, 2017 06:37 PM
jackhammer
Aug 15, 2015 10:04 PM
kyleb24
Aug 15, 2015 08:24 AM
Elliswon
Aug 10, 2015 12:33 PM
