chin scoop?
Old Aug 22, 2006 | 09:42 PM
85 REDBIRD's Avatar
Car: 1985 Trans Am
Engine: 305 carbed
chin scoop?
I am going through all the same problems and frustrations temperature wise that seems to plague most 3rd genners. Went driving around today, trying out my latest thoughts on air dam modifications (and watching the temp steadily rising). I am an aircraft mechanic, and pretty experienced in sheet metal fabrication. A picture started to form in my mind, of a louvered box, that would fit into the "hole" behind my bumper, maybe slanted down to the rear, ending an inch or two above the bottom of the air dam, but flush with the bumper in front. The louvers would angle up and force air into the hole. An alternate idea might be to reverse the slope, forming a chin scoop at the front, maybe 2 or 3 inches or so below the bottom of the bumper (this one would not have a louvered bottom surface), giving some "ram air" to the radiator. Anybody tried anything like this?
Hot in Tucson
Old Aug 22, 2006 | 09:45 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
I can't answer your specific question, but do want to say that my Formula never runs hot. Do you have the dual or single fan setup? Flushed the cooling system recently?
Sorry I can't help with the fabrication questions.
Old Aug 22, 2006 | 09:57 PM
85 REDBIRD's Avatar
Car: 1985 Trans Am
Engine: 305 carbed
Nope, engine driven fan only. New radiator, new thermostat, new coolant, etc.
Old Aug 23, 2006 | 12:15 AM
Bull's Avatar
Engine: LT1; None
Perhaps adapting a dual fan setup to run on your motor would be a worthwhile project? Or an aftermarket electric piece that moves a lot of CFM?
Old Aug 23, 2006 | 11:31 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
How about the Shroud around the Fan?
Old Aug 24, 2006 | 09:01 PM
85 REDBIRD's Avatar
Car: 1985 Trans Am
Engine: 305 carbed
Fixed, maybe
Was taking a good look at my air dam today, and the center section looked bent back a little bit. Compared it to a new spare, and it definitely angled slightly forward. Scrapped the old air dam and installed the new one, then added two straps to connect the center section with the outboard sections. Hopefully, this will stiffen up the center section slightly. Just took it out for a 20 mile test drive, and it never went over 215 degrees, even though most of the drive was at 70+. It's not real hot out today, but I think the heat problem may be solved.
PurelyPMD
May 5, 2016 04:57 PM
dustint209
Nov 26, 2015 12:28 AM
sreZ28
Oct 22, 2015 08:21 AM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
