What do I need for heat? (no vents, or heater box)
Old Sep 16, 2006 | 08:13 PM
transformula87's Avatar
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
When I bought my car it came without a/c and heat. There is no vents in the dash, and there is just holes where the heater box used to be in the engine bay.
My question is what do I need to at least get heat/defrost in my car.
I have the main section of duct work for behind the dash, the wires that are on it and the actual controls.
Is all i need a heater box for the engine bay?
Old Sep 17, 2006 | 03:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
F-bird'88 rigged up a few electric heater's, might want to look into that solution. Saves the heater core, and slow heat up time...
Otherwise, a heater core (the mini rad basically), which you'll have to tear apart your interior to put in, then a few hoses going to your intake manifold and water pump (on a carb setup it is at least). Then that (hopefully) would be it.
Old Sep 18, 2006 | 12:35 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Dont forget to check for the wires that run to the heater motor, and the heater motor if your heater box doesn't come with one.
Old Sep 22, 2006 | 09:34 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
This is what I used Flex-a-lite Mojave Heaters: FLX-640 - summitracing.com
It is compact and puts out a lot of heat. You can buy separately a snap on directional vent cover that also has a 2.5 in heater hose outlet for a defroster connection.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
