keep blowing single fan set up relay
Old Oct 9, 2006 | 01:31 PM
kaptinkafeen's Avatar
Not sure what is going on here. I have the stock single fan set up in my '91Z. All electircal lines have good ground. I just replaced my third relay in the last three months. I do have an inline manual on/off switch that is wired under the dash, but it has been there for many years and has opereated with no fault. Last realy I got was from the dealer, OEM but made in China? (this is what I got from the dealer - part # 14089936) Car is a weekend warrior, and as such this relay has less than 50miles on it. When first installed it operated properly
I disconnect my battery when not driving the car, and am wondering if I am shorting anything out while pulling or reinstalling the bat negative terminal? I have done this for years with no problems.
I'm not sure where to look next - or am I getting faulty relay's?
Is there a way to test a relay at home?
TIA
-Andrew
Old Oct 9, 2006 | 01:43 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
To test a relay (for this example I will assume a NO relay) apply 12Vs to the primary terminals (input) and then measure the resistance on secondary (output) terminals. The output terminals should read close to 0 ohms with 12Vs applied and infinite resistance with the 12V removed.
Old Oct 11, 2006 | 07:37 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I was cookiing relays left and right on my 87.........so I stopped buying them from NAPA, then i bought them from the dealer..........this worked fine. then i saw a thread on here where somebody noted that their old fans were " drawing allot of amps"...........this got me thinking.......when I jumped my relays to see if the fans would run it really let out a good spark as the fans started up...........so just to be safe, I bought two new fan motors from TPI parts.........I haven't blown any more relays.........but i guess I can't say for sure if it was just the change to GM relays.......
Old Oct 11, 2006 | 07:40 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
could be an issue with the fan motor. make sure it isn't binding and turns smoothly.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Bert87
Aug 23, 2015 03:50 PM
