eliminating oil cooler, how to reroute the lines
Old Sep 20, 2006 | 07:27 PM
BOTTLEDZ28's Avatar
Transmission: A4
I'm gong to be ditching the factory oil cooler and I want to clean up some of the coolant hoses running to and from it. Is there a way to simplify the lines going to the intake, heater core and radiator? Do I need that plastic vaccum operated valve that the 3/4" hoses connect to? Can I just get rid of that and run one side of the heater core to the radiator and the other side to the top of the intake?
Old Sep 20, 2006 | 10:48 PM
dyermull3t's Avatar
you intersted in selling the cooler?
Old Sep 21, 2006 | 03:29 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Cooler
Just remove the hoses and steel water tubing.
Your going to want to retain the heater control valve
your referring to or your heater is going to be hot all
the time. Even without turning on the heater fan going
to be warm in the car
I've also got a factory oil cooler for sale. I call them
oil warmers.
Later
Old Sep 21, 2006 | 07:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
I dont plan on selling my oil cooler. I may go back to it at a later date or on another project. As for the heater control valve, its going. If it gets warm inside the car during the summer monthes then I wil just bypass the heater core entirely for the few hot monthes we get here. Its not that hard to just add a feet of hose to the heter core when it gets a little nippliy out. I just now need to find out if the heater core has a devoted inoet and outlet.
Old Oct 3, 2006 | 11:50 PM
dyermull3t's Avatar
jaykar You have a PM about the cooler.
Old Oct 4, 2006 | 12:23 PM
jaykar's Avatar
Okay,
I'll git on it.
Old Oct 11, 2006 | 07:43 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
as a rule of thumb- the larger diameter heater core pipe is the inlet and the smaller diameter one is the outlet..........
Old Oct 11, 2006 | 10:45 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Other way around.
Old Oct 12, 2006 | 06:26 PM
Raiderfan's Avatar
Car: '92
Why get rid of it?
Old Oct 12, 2006 | 09:06 PM
hotrodln's Avatar
Engine: Lt1 in IROC
WHy would the supply be smaller than the outlet? As I understand it, the inlet is always larger to supply the pressure that is lost through the heater core.I have plenty of repair manual s on cars.........but now that I look closer at them, I can't see where there are any diagrams that show the inlet and outlet of the heater cores with their dimensions.....what is it on a third gen?
toronto formula
Nov 10, 2015 06:17 AM
mike_c
Aug 27, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
