making a camaro not a bottom-feeder
Old Oct 14, 2006 | 12:06 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
im currently working to keep as much air from under my camaro as possible. it would help alof if the car didnt REQUIRE air to go under it, which is a stupid idea anyway. if i opened up the entire front grill area, removing or replacing all the braces and everything, would enough air get to the engine to prevent overheating w/o the spoiler underneat? or would additional ventalation be required? what about with aftermarket fans?
Old Oct 14, 2006 | 12:28 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why can't you run the airdam underneath? and camaros aren't just bottom feeders they also take air from the grill area, now TAs are just bottom feeders.
Old Feb 4, 2016 | 04:56 PM
dennisschreuer's Avatar
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: making a camaro not a bottom-feeder
Changed my car from a bottom feeder to front feeder......
Attached Thumbnails making a camaro not a bottom-feeder-before-after.png   making a camaro not a bottom-feeder-ducting-bottom.jpg   making a camaro not a bottom-feeder-front-view-no-grill.jpg   making a camaro not a bottom-feeder-front-view-grill.jpg   making a camaro not a bottom-feeder-top-view-driver-side.jpg
making a camaro not a bottom-feeder-top-view-inside.jpg   making a camaro not a bottom-feeder-top-view-passenger-side.jpg   making a camaro not a bottom-feeder-top-view-top-cover
Old Feb 6, 2016 | 08:34 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'm curious to know why you blocked off below the radiator. I understand wanting to wall off the top and sides of the radiator.
Old Feb 7, 2016 | 09:33 AM
Car: 87 RS Camaro
Engine: LS6
Hi Tibo, 2 basic reasons....
1). Converted to a LS motor series, ran the car at Fontana and incurred heat build up after the second stint.
The car went into an auto dump mode after hitting hi water temp.
Serious cars are front feeders for air, and I installed an oil cooler inside as well capable of handling BTU's for 450 HP.
2). Now that it's a front feeder, I no longer have to worry about feeder air to lower air dam so I can drop the front lip to the track surface.
I still have two 14 inch high cfm fans with a shroud for the street for cycling when there is no air.
Old Feb 7, 2016 | 12:32 PM
Tibo's Avatar
Car: 1991 Z28 Vert
So the coolant temps are lower now with the front opened and the bottom blocked off? My curiosity is high because I've also been modifying the core support and bumper.
I'll have the entire grill area opened and almost totally unobtrused, save for the lower tube of the bumper. If I could just "plate off" the entire area between the radiator and ground effect/spoiler, well that would be nice and easy.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
