JET Cooling Fan Switch
Old Nov 14, 2006 | 05:03 AM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
Hello all haven't been on for a while. Way to involved in my project car and work...(you know that thing that allows us to have our toys )
I have a question today..and probably lots to come ----knew i should never start this project with a garage full of MOPAR stuff LOL
I bought a TPI cooling fan switch for my 86 TPI 305
but i find that none of the temp sensors or switches have a single wire hook up as the Jet switch does. the onlt single wire temp sensor is for the factory gauge.
So where are you suppose to put the lower temp cooling switch?
Do you change the wiring harness to accept a 1 wire as opposed to 2 wire switch?
Old Nov 14, 2006 | 06:45 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The fan switch is located between the #6 and #8 cylinders on the passenger side head, between the spark plugs. Hard to see from above if you still have the OE exhaust manifolds on the motor. The factory wiring harness has one wire going to it...
Old Nov 14, 2006 | 12:50 PM
DocHemi426's Avatar
Car: '86 IROC
Axle/Gears: 4.10
Well thats the one i thought it was as well, But the wiring is all factory and It has two leads.
Old Nov 14, 2006 | 02:47 PM
Wadebryant's Avatar
Go to: http://www.geocities.com/vtcamaro/Wire-Diagrams.html
then look for your vin # under the fan section.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
