What can make this happen ?
Old Dec 6, 2006 | 01:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got a very strange coolant problem .
I was on the dyno and noticed that both top and bottom rad hoses colapse with rpm. Thing is , nothing is comeing out the tail pipe ( cracked head) . I tryed to get it flushed BUT , the heater core is clogged . So we bypassed that for now. Everything is BRAND NEW from air filter to tail pipe. One thing wqe considered is maube the wrong pump came in the right box. As the part numbers on the box are right .
Next we figured that the system had air in it. So I opened the rad and proceded to let'r run. Well after a bit. Coolant stated shooting over the fender in a big arc . It didn;t let up at all. So I stopped that . I tried it twice .
Can a pump with the wrong rotation do something likethis ? Fans work , etc . I had a 180 degree T-stat in it. I took it out to get it into storage. As the coolant alwaqys boils over into the overflow .
Car is in storage right now , so I would like to arm myself with stuff to think about for next season before I put the turbo on it .
Thanx alot Thirdgen.org
Old Dec 6, 2006 | 09:52 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
i have seen bad radiator caps do that
Old Dec 7, 2006 | 06:36 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
I had the collapsing radiator hose problem once. The problem was a hair line crack of the plastic along the upper hose outlet of the radiator which allowed air into the system, creating a vacuum. Not sure if that's the same problem you're experiencing but, you might look for a radiator leak and eliminate that from your checklist.
Old Dec 7, 2006 | 02:26 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
thanx guys. No leaks . All new hoses and whatnot along with water pump . I am wondering if it was the wrong part in the rigth box kinda thing.
Old Feb 9, 2007 | 11:16 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
any other suggestions ? Noth rad hoses are being sucked **** . Ths is something I nver heard of before.
Old Feb 18, 2007 | 09:18 PM
rmartin4677's Avatar
Car: 91 rs-02 blazer old john deer
Engine: 305-4.3
try filling up to top cold seal it back up start car when gets warm look in hose going to over fill tank look for bubbles. any there then head gasket
jhawkeye
May 25, 2022 06:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
mustangman65_79
Sep 1, 2015 03:51 PM
CORV3TT3
Aug 23, 2015 11:26 AM
