thermostat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 10, 2006 | 05:59 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
do you guys recommend ussing silicone with the thermostate gasket or no silicone.... i been doin some research and some people say diffirent things....
they say with using silicone you cant tighten it back up because it spits...
Old Dec 10, 2006 | 06:31 PM
redlsone's Avatar
I use silicone just to be sure but dont think it really matters. To each there own.
Old Dec 11, 2006 | 02:30 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
If done correctly, Permatex Ultra black silicone and a
gasket is virtually bulletproof.
Secret is to lay a consistent bead and lay the gasket
down with thermostat and install housing, do not tighten
bolts right away.. only snug them, after the silicone cures
for a few hours, then torque the housing.
Never leaks for me, and looks great, cant see any silicone!
Old Dec 11, 2006 | 02:44 AM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
I always use silicone, better safe than sorry.
Old Dec 11, 2006 | 11:52 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
What about an O-Ring deisng waterneck. No need for gaskets or silicone.
Here it is:
http://store.summitracing.com/partde...5&autoview=sku
Oh and sorry. I think a gasket might still be needed but the whole should I use silcone might not be needed do to the o-ring design.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
