Cooling Shroud
Old Feb 15, 2007 | 05:02 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Cooling Shroud
Hello everyone,
I'm looking for information about where I might be able to get a new cooling shroud. I'm swapping the stupid little 2.8L out of my '84 Camaro for a 350 and everyone's been telling me 'd00d, you gots ta put a new shroud in thar' so I was wondering where I could get a new one. I know I can probably get one out of a wrecking yard for like $5 but I was just curious what they cost new.
Thanks,
Tony
Old Feb 15, 2007 | 05:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I couldn't find one at the wreckers for the life of me, and I desperately need the bottom half, mine is trashed.
I'm just tagging on in case someone has an idea...
Old Feb 15, 2007 | 06:53 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
dc- Have you considered going to electric fans? They're all over the yards and an easy swap.
Sonix-Seriously need the bottom half? Got one I took out of my LG4 last month. Top piece was broken but bottom is OK. Could be yours for cost of shipping.
Old Feb 15, 2007 | 07:11 PM
Car: '84 Camaro SC
Thanks for the advice. I may very well do that.
However, I'm planning to not use any kind of computer with this swap. Are they a standalone system or do they plug into the ECU?
Old Feb 15, 2007 | 07:20 PM
naf's Avatar
naf
Stand alone. Did your car originally come with one?
Old Feb 15, 2007 | 09:23 PM
Car: '84 Camaro SC
No, it didn't. My current fan is belt-driven. Do the electric ones gove you extra room or do they just take the burden of sucking the air through the radiator off of the engine?
Old Feb 15, 2007 | 09:53 PM
naf's Avatar
naf
In my experience, more room. less noise. better performance. plus it's cooler. pun intended.
Old Feb 15, 2007 | 11:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yes, I need the bottom half. The brackets that hold the shroud against the body are broken off so it just flops around. Very annoying. Yours still has those plastic clips and holds to the body ok? Then i'm game.
Box it up and let me know what shipping is. We can take this to PM.
Old Feb 16, 2007 | 12:59 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
A little more HP with going to electrics as well.
Old Feb 16, 2007 | 02:53 AM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
you need a thermal switch and relay new or out of a junk yard wire or just put a switch to turn the fan on i dont think its wired into the ecm i might be wrong though its 300 am some one will enlighten me though if im wrong
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
