1992 Z28 - Single to Dual Fan Conversion
Old Mar 21, 2007 | 12:42 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
I just bought a complete dual-fan set-up off someone on the board. It comes with the wiring harness and all.
Is it a simple conversion? Just take the old single fan out and put in the dual? I have both the upper and lower mount and everything coming with the fans... but just wanted to know what I'm in for before I do it.
Old Mar 30, 2007 | 03:26 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: 1992 Z28 - Single to Dual Fan Conversion
Need more info about the wiring harness -- are both relay
circuits included? Each fan needs a dedicated power relay.
The dual fans are controlled by (1) - ECM output, and (2) -
AC system output to a relay. The single fan relay is
by a temperature control switch. You'll need to add another
high current/constant power (10 - 12 gauge wire) for the
additional relay. I think the single fan system has the AC
pressure switch, to which you can add the additional control
input for the second relay. If you need more detailed info,
PM me. Hope this helps.
Brinkkl2000
Aug 4, 2018 08:29 AM
diana227vegas
Jul 8, 2016 12:27 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Bryan F
Aug 18, 2015 02:28 PM
