83 Ram air
Old Mar 29, 2007 | 09:49 AM
emi_16's Avatar
Car: 1983 Z28 Camaro
Engine: Crossfire Injection 305 V8
Axle/Gears: 2.8??? stock fer sure
83 Ram air
So now that i have my ram air hooked up correctly. Now i want to know at what gear or RPM the ram air is suppose to engage
Its An 83 Camaro LU5 CFI 305
-Thanks
Old Mar 29, 2007 | 10:18 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: 83 Ram air
I have never seen a camaro with ram air? Could you please post a few pics of your setup? Is it factory or aftermarket?
Old Mar 29, 2007 | 06:29 PM
emi_16's Avatar
Re: 83 Ram air
Its a factory installed.
Old Mar 29, 2007 | 06:56 PM
j dezzy's Avatar
Car: 87 TA
Re: 83 Ram air
You've got the stock "flapper" unit?
Old Mar 29, 2007 | 07:11 PM
emi_16's Avatar
Re: 83 Ram air
Yea i got the flaps
Old Mar 30, 2007 | 10:59 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: 83 Ram air
The air door solenoid is controlled by the ECM.It takes a signal from the TPS that you're at full throttle(above 75% I believe)in any foward gear.But only after the motor is at mormal operating temp(the ECM goes into closed loop).
below are pictures of the air door assembly on my '83.Looking at the picture I need to clean the underside so please excuse.
Attached Thumbnails 83 Ram air-100_0059cfiunder.jpg   83 Ram air-100_0060cfidoorclosed.jpg   83 Ram air-100_0061cfiairopen.jpg
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
edoff13
Sep 11, 2015 03:55 AM
09ave
Sep 7, 2015 06:03 PM
