both fans running?
Old Apr 1, 2007 | 01:16 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
both fans running?
I noticed both my fans started coming on all the time when i start the car.They used to be wired that way when I bought the car,but when we put in the new engine I had them rewired and they were coming on at 190 degrees.Any reason they would just start doing that?
Old Apr 1, 2007 | 06:01 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: both fans running?
Were they running on a switch in the intake manifold?
If that is corect the wire could have come off the switch and grounded on the intake making it run constantly, If it is still connected than there is only 2 other things i can think of 1. Look and see if the wire has been cut and is shorting out on something 2. Replace the temp switch in the intake.
Hope it helps
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
