fan problems
Old Apr 10, 2007 | 01:51 AM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
fan problems
i have an 87 iroc with the dual electric fan but the secondary fan does not turn on what could be the problem?
it has some bosh relays that how i got it and therese like this sensor thing stuck in the radiator i bridged it and my secondary fan will turn on when the switch was on with the primary one but it doesnt work nomore what could be wron i checked the fuses and tere fine why does it have that thing stuck to the radiator?
Old Apr 12, 2007 | 07:22 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: fan problems
That thing stuck in the radiator may be a temp probe, It tels the fan to come on at a set temp.
So you are saying that if you bridge the probe it will turn both of the fans on or just the secondary one?
The probe may be faulty or just set at a real high temp.
How hot is the car getting?
For a quick fix bridge the two wires coming out of the probe togeather and that will engage the fan/fans when you turn the ignition on. (I think)
Only if you realy need the second fan, If it is not getting real hot just run one.
Old Apr 12, 2007 | 11:01 PM
jessc50's Avatar
Re: fan problems
i had the probe bridged and it was working fine with the ignition but it stopped working i dont know why.. i do need the second fan because the car gets to 3/4 + buit after it been runnig for about 20min
thanks
Old Apr 12, 2007 | 11:41 PM
VenomX-87's Avatar
Re: fan problems
ok it may have blown a relay, to test thoes two relays swap them over.
If the secondary fan starts to work but the primary dose not then it is a relay that is youre problem.
Now unplug a relay if one fan still runs then you have the dead relay in youre hands, IF once you dissconected one relay and both fans are not working you are holding the good relay.
Just thought id ask what AMP are the relays?
I wouldent use anything less than 20/25A preferably a 30A for thermo fans.
Old Apr 13, 2007 | 12:18 AM
jessc50's Avatar
Re: fan problems
i cheked the relays and when i swithed them the primary fan turned on but the second one didnt then i switched them again and the primary fan turnoed on but the the second I was bridging the probe while doin this but it the secondary fan still didnt turn on
Old Apr 13, 2007 | 12:28 AM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
Re: fan problems
check to make sure you are getting 12 volts to the fan when warmed up if so bad motor if not wiring fault
Old Apr 13, 2007 | 12:29 AM
jessc50's Avatar
Re: fan problems
how do you check the voltage
Old Apr 13, 2007 | 03:47 AM
VenomX-87's Avatar
Re: fan problems
multimeter, they are like $8 at a auto store.
the person working will be able to tell you how to use it, it is kind of hard to explane it without showing you.
Old Apr 13, 2007 | 08:48 PM
jessc50's Avatar
Re: fan problems
thanks for the helps guys ill see if i could fix it
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
