heater hose routing
Old Apr 12, 2007 | 06:46 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
heater hose routing
I have a quick question. I bought a howe aluminum radiator, i just installed it today. there is no provision on the radiator hose for the heater hose. can I hook that hose up to the water pump or should I make a hole in the radiator for the fitting for the heater hose. I don't know if putting it to the top of the water pump will mess anything up or not. if anyone knows what I am talking about and has an answer i would appreciate it more than you know. its the last thing i have to hook up before I can drive it.
Old Apr 13, 2007 | 04:03 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: heater hose routing
You can run the heater hose to the water pump will not affect anything. My hoses are hooked up this way.
Old Apr 13, 2007 | 06:36 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
ok thanks. i thought it would be ok. but I wasn't sure. sweet now i can fix it and go for a drive. thanks again.
Old Apr 20, 2007 | 10:23 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
ok so i routed the hose to the water pump. this is a serp system I don't know if that matters. but my t-stat opens at 190. then it drops to 140 and works its way back up to 190 then 200 then 210 up to almost 230. I know my fan works but it does not come on untill 230. i don't know if this is normal. what iis the normal temp your cars run at. I thought with a 190 t-stat that the car should be around 205 or so. i have an aftermarket fan(moves alot of air). and an aftermarket temp gauge(installed on in the drivers side head).
The radiator is massive and I know i should not have a prob with cooling. thansk for any help.
Old Apr 21, 2007 | 02:31 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
ok i have just found out that my car's fuel preasure is at about 3 psi. i have a tbi pump with a mallory afpr and a guage right off the afpr it is saying a little over 3. i tried to turn it up but it would not go up. i could get it to go down but not up. now would this be my heating prob?
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
