relocated coolant res.
Old Apr 17, 2007 | 11:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
well i was doing some other work on my car on the coolant system so i thought i would get rid of my old ugly brown coolant reservoir. i got this universal res. from autozone for like $10 but i couldn't mount it anywhere so i made a battery tray with a tall side so i could mount it on there
Old Apr 17, 2007 | 11:05 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: relocated coolant res.
IMHO you should have sprung for a new bottle
Old Apr 17, 2007 | 11:10 PM
johnnyboy's Avatar
nah, i don't really like the look of that huge bottle sitting on the wheel well. and for $10 i don't see any better possibility. the old bottle was disgusting and filled with rust, a previous owner somehow dropped beer bottle caps into it. it wasn't pretty to say the least.
Old Apr 17, 2007 | 11:35 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Hope ya don't need to get a jump start anytime soon.
I'm going with the 4th gen style which relocates to underneath the battery. It's black and all you end up seeing is the filler tube.
Old Apr 17, 2007 | 11:39 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I know what you mean about a cleaner look. I got a resovoir tank from a minivan (long and skinny) at the bone yard. I plan to put it under plate where the hood latch is. I need to find a way to make a hole to have easy access to fill the bottle before I can install it...
Old Apr 17, 2007 | 11:49 PM
johnnyboy's Avatar
i had thought about putting the bottle under that pan where the hood latch is but i didn't want to have to put a hole in the sheet metal. and i can easily get to the positive terminal on the battery and i can put the negative anywhere else.
Old Apr 21, 2007 | 02:57 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I like it, and is now probably going to be the way I do mine. My pcm will be where the coolant resivoir was, so I'll be putting my coolant tank just forward of that. Now I need to get a mount set up, as my battery is on the driver's side.
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
