Hot air always coming through vents, how do I fix it?
Old Apr 24, 2007 | 09:06 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
I did a search, but nothing really turned up. So here's the problem: Even when the heats not on, the blower motor's off, and the engine's warmed up, there's a constant flow of hot air coming out of the vents under the dash. And when the heater and blower are actually turned on, it acts like it would normally. This the first summer I've had with the car so I guess I never noticed this before because whenever I was in the car this winter, the heat was usually on anyway. But now that spring is finally here, it's gotten a lot more noticable. How do I fix this? If I had to guess, I'd say a vent is stuck open somewhere. Any help or advice would be appreciated.
Old Apr 27, 2007 | 02:30 PM
mike_c's Avatar
Re: Hot air always coming through vents, how do I fix it?
Anyone?
Old Apr 29, 2007 | 01:28 AM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
Ive got the same problem with mine, but the hot air comes out about the dash and hits the windshield causing it to fog up. Wish i knew what the problem was.
Old Apr 29, 2007 | 03:57 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
More than likely a vacuum leak somewhere causing the vents to not close fully. My 87 Grand Prix did it, and my 85 Trans Am does it. The vents just don't close when the blower is off, and air finds it's way in.
Old Apr 29, 2007 | 06:19 PM
j dezzy's Avatar
Car: 87 TA
my 91 bird did it, my 87 camaro did it, and my 84 TA did it...my TA didn't have any of the AC or heating elements under the hood. Buy the coolant hoses were still routed through the heater core. So I went ahead and pulled the heater core. no more heat coming through.
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
