How to remove AC box from firewall????
Old Apr 25, 2007 | 11:21 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have an 84 Z28 and I am trying to remove the AC box from the firewall. I have removed all on the screws from the firewall but it still wont come out are there and screws that I need to take off inside the car???
Old Apr 25, 2007 | 12:15 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: How to remove AC box from firewall????
There should be 2 or 3, pull back the carpet and they are right there.
Old Apr 25, 2007 | 12:22 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok first i want to say that i am sorry for the pic, not the best but hope it helps. there are 2 or 3 screws on the top, one on the side that is a bolt you take off then i think a ground wire then another bolt, and there are 3 on the bottom that you get to from inside. i tried to put the arrows as close to where i think they are. they will be in the inside where the passenger's feet go, you might have to pull back the padding a little. [IMG][/IMG]
if you need a better pic let me know i can get you one, this is all i had at the time
Old May 13, 2007 | 08:00 PM
Kano_RS's Avatar
Ive did that yesterday, however my A/C box setup looked a little different (89)
However, remove the 10mm bolts u have circled and just shake it. The entire unit is cyliconed to the firewall. Use a screw driver to seperate it, or as i did - just rip it out
Old May 13, 2007 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its not siliconed to the firewall, some one must have f-with yours
there are 2 screws by the passengers feet remove the lower dash piece and pull back the carpet a bit and you will see them there, make sure you take out the right ones, i think there are 1 or 2 that hold on something else and not the ac box
Old May 22, 2007 | 07:15 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
I just ripped all my heater/a\c junk out yesterday and I can tell you there are 8 total screws holding the a/c box onto the firewall (4 from firewall, 4 from passenger side footwell). There is a gasket that goes around the outside of the whole a/c box which you kinda have to pry it off from, other than that it should fall right out...
Old May 31, 2007 | 04:23 PM
88trans_am_gta's Avatar
Car: '88 gta
Engine: 350 tpi
hmm, well, that explains why my a/c box refuses to budge, bolts in the passenger compartment eh?
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
fbirdroller
Sep 2, 2015 10:27 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
