Quick Question on heater core delete
Old May 31, 2007 | 10:01 AM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
I am in the process of doing a heater core delete on my Z28. My question is, what should I use to plug the water pump where the heater hose went? I thought it might be threaded, so I planned to use a threaded pipe plug, like the kind you get from summit, however it isn't threaded. Has anyone done this before? What did you use?
Old May 31, 2007 | 02:16 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: Quick Question on heater core delete
show a picture.
what I did was put a hose from the intake to the pump directly instead of looping through the heater core. without this setup i had lot of high temp fluctuations.
Old May 31, 2007 | 08:14 PM
Engine: 383 Stroker
I just ended up getting fed up with hoses and put pipe plugs in the intake and water pump. Seems to have solved the problem
Old May 31, 2007 | 08:25 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I would just loop the heater hoses together with a small piece of pipe, like you do with the TB bypass.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
