A/C only blows out of defrost
Old Apr 30, 2007 | 09:31 AM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Anyone know why my ac only blows out of defrost. When I put it on norm ac and max ac it comes out the dash defrost only and not the vents.
Old May 1, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: A/C only blows out of defrost
Defrost is the default. You have a vac leak somewhere. As your problem is common to thirdgens, a search will provide a ton of info.
JamesC
Old May 7, 2007 | 01:48 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
mine did that too. you have a vaccum problem or dirty controls. put your car in low gear, drive it up to about 4000rpm and back off the gas while you wiggle the switch back and forth. this will create a lot of vaccum that could break loose a sticky valve in your HVAC system. thats what fixed mine, never been a problem since...
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
scottmoyer
Sep 7, 2015 07:06 PM
