temp degree
Old May 8, 2007 | 08:48 AM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
temp degree
on an camaro wit a guage that shows from 100 to 260....what does your car suposed to run at.
Old May 9, 2007 | 10:34 PM
Car: 86' Z28 Camaro
Re: temp degree
Old May 9, 2007 | 10:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: temp degree
My Camaro runs at 190-200ish.
Old May 10, 2007 | 08:18 PM
91 355 z28's Avatar
Re: temp degree
between the little line between 100 and 220 which is 195, and 220 is normal.. ive hit 240 on hot summer days im getting a chip made and switching to a 180 stat soon tho.. u can only switch if u get a chip tho
Old May 14, 2007 | 07:29 PM
Crazy 84 Z28's Avatar
Car: 1984 Z28 Camaro
Engine: 305 H.O. 72,000 original miles
Re: temp degree
When I am cruising at 30 mph or more I run about 180 degrees, now when I am below 30mph I run at 220 degrees and my cooling fan kicks on.
A normal radiator temp is between 195 and 220 degrees
Last edited by Crazy 84 Z28; May 14, 2007 at 07:31 PM. Reason: Automerged Doublepost
Old May 14, 2007 | 07:31 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Re: temp degree
The manual likes to make you think as long as it's not in the red your good to go. I would say around 190-200 range.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
