Want to remove all a/c heat controls how too ?
Old May 11, 2007 | 08:07 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I am removing all of the a/c and heat stuff from my car since its a summer car only and nothing close to stock any more. I already have the a/c box off the fire wall and the heater core hoses have been plug and also the water pump and intake. What do I do with all of the wiring ?? I dont want to hack up the wiring I want to be able to put this car back to stock If I have to.
Old May 22, 2007 | 07:22 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
Re: Want to remove all a/c heat controls how too ?
good luck without hacking it up, unless you take out the whole dash. I hacked mine all up just 'cause I wanted it out. I took all the ducting out as well, the parts behind the radio area were the hardest.
Old May 22, 2007 | 07:48 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The wiring harness for heat and A/C is a seperate harness that can be removed. It runs through the firewall near the rear of the intake. It can be removed without cutting or damaging. Once you disconnect all of the wires from the controls yhere is one more wire on the inside. It is a brown wire that supplies power to the entire system.
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
BikeFarm
Aug 11, 2015 11:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
