transmission line exploded
Old May 20, 2007 | 01:54 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
my transmissions cooling line popped, and now i need to fix it.
anyone know where to get a nice new one? and any tips on how to take those hoses off, it looks like a pain with my current tools.
help would be much appreciated. thank you.
Old May 20, 2007 | 01:57 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: transmission line exploded
rubber hose em back together and take it to a shop with the right flare tools.
Old May 20, 2007 | 02:00 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I replaced mine with flexible lines then installed a better transmission cooler. The flexible lines made it easy to route it away from the starter and my headers which the stock metal lines interfered with. Maybe you could consider that? It was easy and cost under $80 including the B&M cooler.
Old May 20, 2007 | 02:26 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
its really not my car, but my sisters, i just want a cheap and easy fix as i have to break the price to them. how expensive would a shop be?
Old May 21, 2007 | 05:07 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
fix it with rubber lines if you want a cheap fix. use two hose clamps when you slide the rubber line over whats left of the tranny solid line.
Old May 22, 2007 | 10:11 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Make sure your rubber hose is transmission fluid or hydraulic rated hose! I have added transmission fluid coolers to all my vehicles and I always use those hoses and have never had a problem.
Old May 23, 2007 | 12:05 AM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
ok, thank you
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
ydnar417
Sep 23, 2015 05:57 AM
Dialed_In
Aug 20, 2015 01:45 PM
