electric water pump install?? wtf
Old May 23, 2007 | 05:28 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
i just got a pro comp electric water pump, and im in the middle of installing it. untill i started to fill the coolent back up when antifrezze starts wizzing out the passengers side of the block below the bottom bolt for the for the pump. now my stock pump covers this up. wtf is going on? i was thinking of getting a small frost plug like the block takes just above the camshaft but smaller. am i missing pieces?this ever happen to anyone else?whats the fix?
Old May 23, 2007 | 11:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: electric water pump install?? wtf
On older blocks that hole is drilled for the water pump bypass. You can use a cup plug, or tap it for a pipe plug.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
