getting oil in my ratiador help!!!!!!!!!!
Old May 5, 2007 | 07:46 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
hey guys i'm desperate for help,i made a discovery today i was cheking my water in the radiator and discovered that the water has a bit of oil in it , i'm scared cuz i dont know what happened. my question for you is what happened and what can and should i do. please help!!!!!!!!!!!!
Old May 5, 2007 | 09:02 PM
Grippo's Avatar
Car: '87 IROC, '87 K-10, '95 Ranger
Engine: 350 Tpi, 350 Carb, 4.0 EFI
Transmission: T-5, Turbo 350, Mitsu. 5-speed
Re: getting oil in my ratiador help!!!!!!!!!!
Check your oil and see what that looks like. It sounds as if you have a bad head gasket.
Old May 5, 2007 | 09:26 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
i cheked the oil and it looks normal, no bubbles or any signs of water in it.
Old May 5, 2007 | 10:54 PM
brad_26's Avatar
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
dose it look light brown ? if not i guess cheapest insurance if you think something is wrong is change the oil and take a pic lol
Old May 5, 2007 | 11:51 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
i cheked the oil and it looks good, it's the water in my radiator that looks like this
damn dude i'm so freaken scared right now
Old May 6, 2007 | 12:00 AM
brad_26's Avatar
Car: 1984 camaro
umm dosent look good i hope thats not your olny car
A blown head gasket.
A leak in the tranny cooler line for your transmission
was the car running a little bit hot under acceleration ?
if you have someone there take the radiator cap off(when its cold) fill it up if its low have someone start motor and rev it if the coolant starts to over flow the radiator you have a leak
Old May 6, 2007 | 12:26 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
and if it's a leak, it's going to be in the tranny cooler line? if so how can i fix that? sorry but i'm so worried right now
Old May 6, 2007 | 12:28 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
ok, i did that and the radiator didnt over flow, so that mens that i have a blown head gasket? and if so how much would that cost to repair? sorry but i'm not a mechanic like some of you, that is just too risky for me to do by my self, i'm afrade of screwing it up
Old May 6, 2007 | 04:26 PM
brad_26's Avatar
Car: 1984 camaro
lol no it did'nt over flow so it means its prolly NOT a head gasket have to look else where
Old May 6, 2007 | 06:01 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Check both the transmission and engine oil dipstick, and leave the cap off the radiator and don't drive the car around.
If the tranny fluid looks similar=new radiator needed+trans flush asap, which can happen as well.
Old May 7, 2007 | 12:41 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
and will that fix my problem?
Old May 13, 2007 | 01:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is there water on top of that brown stuff, if not maybe thats just ALOT of rust!Wouldnt the water seperate from the oil.Looks like its all mixed together in the pic!
Old May 20, 2007 | 07:19 AM
surfertom's Avatar
Car: 86 Z-28
Transmission: 700-r4
looks like trans fluid to me , there is a seperate tank inside your radiator for cooling the trans and its leaking into your coolant. change out your radiator , should be able to find 1 pretty cheep in the classified threads. or get a new 1 from your local shop. check your trans fluid level i bet its down a bit.
Old May 20, 2007 | 08:20 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Whats wrong with the coolant? Looks a healthy brown to me. Put it back in, you got a couple more years with that.
Old May 24, 2007 | 01:11 PM
coincounters's Avatar
Car: 1984 z28 ho
Engine: L69
I had this happen to me last year. It looks like tranny fluid in the radiator. First you need to replace the radiator,(if its metal and plastic, it cant be fixed). Second you need to flush the tranny and change the fluid and filter. If your lucky you didn't do much damage to the clutchs, if not you will find third and forth gear will start to slip, about 3500 rpm and it's rebuild time!
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
