Opinion needed for higher pressure Radiator Cap
Car: 1989 IROC
Engine: L98 350
Axle/Gears: 3.45 posi 1LE
I thought of buying a higher pressure radiator cap for my 5.7 IROC. The one I have now is a month old Stant 16 lb. ventilated Lever Cap. Would an 18 lb. vented cap be better, to keep more fluid in the radiator to cool the engine? It seems too much radiator fluid is going into my overflow.
Thank you for your response.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Opinion needed for higher pressure Radiator Cap
All a higher pressure cap is going to do is allow the coolant to get a couple degrees warmer before boiling over. It won't fix any cooling problems that are causing it to boil over in the first place.
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Hi old Phart,
This is more of a cooling question so I'm moving it to the Cooling board.
Apeiron speaks wisdom btw.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Define "too much fluid".
What temp is the car running at? Change the thermostat to adjust your temperature, not the radiator cap.
Car: 1989 IROC
Engine: L98 350
180 thermostat, temp around 210, 100 degree Arizona "dry" heat. Just want to keep more coolant in the radiator.
Thanks.
Thanks.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds more along the lines of you need a more efficient cooling system. Increasing the pressure is more of a bandaid, as Ape said.
You could use an 18lb cap, no problem. I run a 24lb cap, but I don't have a stock cooling system. Just a side thought, have you tried pressure testing your current cap? If you're losing coolant to the overflow at a pretty good rate, your current cap could be weak.
Engine: 383 Carb
Transmission: 4L60
There should never be coolant overflowing into the reservoir unless the engine becomes seriously overheated. If that does happen though, the purpose of the reservoir is to catch the overflowing coolant and recycle it back into the system as the engine cools, so that you're not stranded with a dry rad.
Car: Camaro RS 1991 305 TBI
Engine: 305 LO3
Transmission: automatic
Axle/Gears: stock
Hi: one question: turn on a/c is better to cooling or not?
Engine: 383 Carb
Transmission: 4L60
Turning on the A/C increases the load on the engine, producing more heat. The ECM will turn the fan on when the A/C is running to compensate.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Turning your heat on will help a bit....actually quite a bit. My brothers Blazer used to heat up quicker than all hell....so we started driving around with the heat on...kept it at operating temp...at lights or stops it would go up a little but not enough to overheat anymore....so if you have a small heating problem turn the heat on for a bit.
P.S. I bought a 19lb Moroso cap...I also have stewart stage 2 pump, 180 stat, silicone hoses, Royal Purple Coolant Additive. Coming soon will be griffin radiator, flex-a-lite tranny cooler. Then I'll be done for a while on my cooling system....as I soon will want to go auto-x or track racing.
Engine: 305 LO3
Axle/Gears: stock
hi guys , whith a/c turn on,the R.P.M. of fan(single) are hi or not ?
Engine: 383 Carb
Transmission: 4L60
I didn't think there were any single-fan setups with A/C. Our fans are single-speed, so the fan is either on high speed, or off.
1992 Trans Am
May 10, 2023 07:19 PM
