i'm lost! realy! please help.
Old Jun 6, 2007 | 08:24 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
ok guys, i thought that i had found the cooling fan relay but i'm not sure if its the right one so i got some pics 4 u 2 show me the real cooling fan realy,
hey can any of you please tell me where this white wire goes to, cuz the previous owner was tapping into this relay looking thing with a switch inside the car and i would like to reconnect it to where it should go. thank you very much in advance
Old Jun 6, 2007 | 09:00 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: i'm lost! realy! please help.
Im 90% sure it is the one near the Battery/Radiator
Old Jun 7, 2007 | 12:12 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
cool, thanks . now all i need is for someone to tell me where that white wire goes, i think maybe thats why my cooling fan isnt kicking on, so please relpy, thanks.
Old Jun 7, 2007 | 10:34 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
please, can someone please tell me where the white wire goes and connects to please please, thank you.
Old Jun 7, 2007 | 11:40 PM
VenomX-87's Avatar
try searching these two pages
http://www.austinthirdgen.org/module...ody_wiring.gif
http://www.austinthirdgen.org/module..._continued.gif
Hope they help.
Old Jun 8, 2007 | 11:33 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I thought the cooling fan relay was the one on the firewall by the brake booster, the relay had a blk/red and a blk 10 or 12 ga wire to the fan.
Old Jun 8, 2007 | 06:45 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Originally Posted by VenomX-87
didnt find anything for cooling fan relay, mostly ac stuff, thanks tho.
Old Jun 9, 2007 | 06:53 AM
Cooling fan relay
I'm not sure about the other wire. That looks like the fuel pump relay; but as far as what the PO hacked, iunno. Find another hacked white wire and hook them back together in an un-hack-like way, I guess.
It's amazing sometimes how a little software (image processing) goes a LONG way.... this was Paint Shop Pro. Cheap and highly effective.
Old Jun 9, 2007 | 09:01 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
That should be the fan relay, although I've had another member on this board claim it was the fuel pump relay for his model/year. Not confirmed.
Easy enough to cypher out. Just do a continuity check between the relay leads and the hot wire to the fan motor. It will be one of the two thicker (larger guage) wires on the relay. One will be constant 12 volt the other will be the lead to the motor.
ZZ3Astro
Aug 13, 2019 12:57 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
Numbah-1
Oct 2, 2015 08:27 AM
3.8TransAM
Sep 27, 2015 08:37 PM
