Royal purple - purple ice!
Old Jun 9, 2007 | 12:10 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
The other day in michigan we had some 90 degree weather and my Trans Am reached 220 despite the fact that my cooling system is all brand new and my air dam is in place. I decided to get some water wetter but napa did not have any and the sales person said to try royal purples purple ice. I got a bottle of it and it did drop my temp down 20 degree's...great product IMO. Now I need my cowl hood to help keep under hood temps down...also I am running hooker 2055's and they are ceramic coated but they still seem to raise my under hood temp so I am thinking about wrapping them with some header tape?
Old Jun 20, 2007 | 02:31 AM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Re: Royal purple - purple ice!
I've read that wrapping headers with thermal tape works well, but not in areas that have high humidity. The humidity will eat the headers from the inside with the tape on the headers. The temperature stays inside the headers and cooks the water instead of pushing everything down and out. Just what I've read/seen. Search around here and you might see the same thing.
Old Jun 20, 2007 | 06:48 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
What you said about the headers is true, but he mentioned his headers were ceramic coated, no exposed metal...
As for 220 degrees, that's the factory temp that the fans usually turn on...
Raf
Hotrodboba400
Dec 10, 2019 07:07 PM
3rd gen money
Oct 11, 2019 09:57 PM
Elephantismo
Feb 13, 2019 12:51 AM
blackz281le
Jan 11, 2016 07:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
