Electric Fans/ Air Condition
Old Jun 10, 2007 | 02:02 PM
Benny K's Avatar
Car: 91 Z28
Engine: TPI 350
91 Z28 350TPI
When is the Passenger-side fan supposed to come on? It never turns.
Driver Side is Working fine. Starts to run at about 220 degrees...but only drivers side.
Should'nt there be at least one fan going on when you turn on A/C?
Im a car mechanic myself and I will check the problem in the next days...but I need some info about how the fans are supposed to work before I start searching
thanks and greetings from Switzerland!
Old Jun 11, 2007 | 06:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Electric Fans/ Air Condition
Yes. For more info, check the stickies at the top of the page.
JamesC
Old Jun 12, 2007 | 04:27 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
If you're low on A/C refrigerant, you won't develop enough pressure to turn on the 2nd fan.
When I had the stock fan switch and low on A/C refrigerant, it would never turn on the 2nd fan. Wouldn't get the coolant hot enough or enough A/C pressure. I used to wonder if it even worked.
Went to a 200/185° fan switch and fixed the A/C. Works with both now.
Old Jun 12, 2007 | 05:07 PM
Benny K's Avatar
Car: 91 Z28
Engine: TPI 350
the stickies do not work at the moment ? ?
drivers side fan comes on when I turn on A/C (wich is freshly filled)...and it starts to run when I hit 220 degrees...
checkes both relays today..they are ok...however...passenger side fan doesnt turn...but it would work...I connected it to the battery and it turned.
Under wich circumstances will the second fan on the passenger side be activated? and by what will it be activated?
Old Jun 12, 2007 | 05:57 PM
Car: 1989 GTA
Cooling fan specs
235°F coolant temp (monitored by the fan switch in your passenger cylinder head between #6 and #8 spark plug)
or
A/C high pressure at 233 psi or higher.
If that link doesn't work, delete the first part of the address up to the 2nd http part.
Old Jun 13, 2007 | 02:50 PM
Benny K's Avatar
Car: 91 Z28
Engine: TPI 350
Thank you very much!! thats exactly what I need for proper diagnosis!
hate to work without factory wiring diagrams!
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
