A/C high pressure switch replacement?
Old Jun 20, 2007 | 08:59 PM
Roc87's Avatar
Car: '01 Vette 'vert
Engine: Ls1
Transmission: 6sp
I just swapped out the A/C compressor, accumulator and oriface tube in the elky (AKA '88 TPI GTA), and I couldn't get the secondary fan to come on when charging the system. I put in 3 cans of R134a, and around 2 oz of oil, after the system had been vacuum for around 30 minutes. After all that work I found out that the high pressure switch isn't working to turn on the secondary fan. I know the low pressure switch has a schrader valve on it, so you can change it without opening the system, but is that true for the high pressure switch? I really don't want to open the system again.
FWIW, I have around 35psi low side and around 240psi high side pressures.
Old Jun 20, 2007 | 10:25 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: A/C high pressure switch replacement?
There is a valve in that connector. Might unhook the wires, short them together and see that the fans both come on.
Old Jun 22, 2007 | 12:29 AM
Roc87's Avatar
Engine: Ls1
Transmission: 6sp
Yep, I jumped the connector with a paperclip and wrapped electrical tape around it to make do, and they both come on... Just don't want to leave it like that. Thanks for letting me know about the valve
92camaroJoe
Jul 29, 2023 07:57 PM
jackhammer
Aug 15, 2015 10:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
