I'm screwed, need help
Old Jun 24, 2007 | 03:46 PM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
hole in radiator. starts as soon as you start car. will a 87 2.8 auto radiator work for a v8, only thing I have available. this sucks bad, I gotta go to work but can't drive there.
Old Jun 24, 2007 | 04:31 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Re: I'm screwed, need help
Just go buy a new one for like 150 its not that much
Old Jun 24, 2007 | 04:53 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Is it the same or near same size as your stock radiator? If it is and the hook-ups are in the same location give it a try.
Old Jun 24, 2007 | 07:46 PM
BlueSmoke's Avatar
Engine: 5.0 LO3
looks to be same size but hook ups are reversed. don't have the money to buy one this blows.
Old Jun 24, 2007 | 07:54 PM
Axle/Gears: Stock
make it fit...if they are reversed turn the radiator upside down duh!!! haha jk really save money and buy a new one
Old Jun 24, 2007 | 08:27 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i bought an aluminum v8 radiator... it runs GREAT. what i had to do was buy extra tubing and 2 little metal (don't get plastic) pipes from lowes for 3-4$ a piece. 2 1/2" and a few more clamps. i don't have any pix, but it looks just like a v8 setup.
the pipes are like elbowed. 6-8" long, a 90* turn, and then a couple of inches and a lip at the end. The top will be extremely snug, the bottom should pop right into place.
Old Jun 24, 2007 | 09:28 PM
88trans_am_gta's Avatar
Car: '88 gta
Engine: 350 tpi
ive got a plastic radiator outta a '90 rs 305. only thing missing is the draincock. if you want it, im only looking for the shipping price, let me know.
Old Jun 25, 2007 | 02:09 PM
BlueSmoke's Avatar
Engine: 5.0 LO3
so i filled up the radiator and went to get bar's stop leak. HUGE puddle of coolant under the car when I returned. I see the leak in the radiator but I dont think it's the cause of this puddle. It's on the driver's side, the feed hose at the top isn't leaking. I don't remember dragging the car any at all. What else is under there that could be leaking that bad.
Old Jun 25, 2007 | 02:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
is it leaking under the radiator
or under the front of the engine ?
only you can aswer as to where its coming from
you will have to just look and see
if its driver side hten it could be the therm housing gasket, but then it might still be leaking from the pass side of the radiator and traveling across the rad support and falling off the driver side
so...
its either going to be a hose, or the radiator, or the water pump or the thermostat gasket
tanks are known for cracking on these
new radiator can be had for a little less than 150 if you shop around, advance auto has one for 117
Old Jul 1, 2007 | 06:34 PM
BlueSmoke's Avatar
Engine: 5.0 LO3
It was leaking where the aluminum clamps on the plastic tanks, bars stop leak fixed that. About 3 days later though at least 3 new spots started spraying so it is trash, even though they do not leak all the time, I'm no HVAC professional but that doesn't make sense to me. So a buddy brought me a copper one he forgot he had and it doesn't leak. Everything is the same except no neck that hooks up to the heater control valve. Is there somewhere else I can hook that up as I do need the heater.
Old Jul 1, 2007 | 07:54 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
I wouldent use any stop-leak unless you have no choice (in the country and you have to get home to get a new radiator), It creats a buildup of c##p that blocks/narrows passeges in the engine/radaitor and causes overheating later on down the track.
Before you install youre new radiator (when you get it) id advise you to run a cooling system flush product, All youre cooling system leaks will show up because the system flush will be removing all the stop-leaks c##p and cleaning the water passeges in the block.
Old Jul 2, 2007 | 07:54 AM
BlueSmoke's Avatar
Engine: 5.0 LO3
Yep I flushed it twice, that's when the radiator leaks started. Stop Leak was a quick fix, the way it was leaking, I doubt much of it made it to the block. So what about the heater control valve problem gotta hook this new radiator up , just don't know what to do about the heater.
Old Jul 3, 2007 | 09:16 AM
BlueSmoke's Avatar
Engine: 5.0 LO3
Ok so some extensive searching I think I know how to bypass the heater control valve. Power steering pump whines like hell and bleeding and fluid change doesn't do any good so I'll throw one on there while I'm working there. While I'm clearing up that mess though I thought about removing the air pump and air conditioner compressor, it is bad anyway and would make spark plug changes a hell of alot easier. Can I completely do away with both without the delete pulleys on a serpentine belt setup? I mean completely remove not reroute the belts.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
