Toggle switch for Single Fan
Old Jul 1, 2007 | 10:45 AM
gmtofd's Avatar
Hi,
Picked up a '88 Trans Am that I would like to use as a temporary driver
Would like a simple explanation of wiring a toggle switch to the fan relay on a '88 Trans Am. The car was originally a 305 thottle body, and now has a crate 350 with no heat sensor screwed into the a head to monitor fan control. Looking underneath, on the lower right side of the fan, there appears what looks like a relay.
Does someone know the color code for the wire to splice-in a toggle switch hooked to 12V to get this fan to start working?
Thanks for any response.
Old Jul 1, 2007 | 12:05 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Re: Toggle switch for Single Fan
should be a ground, not 12v to trigger the relay. got a green and white wire coming out of the connector? try grounding it with the ignition on.
Old Jul 2, 2007 | 06:47 AM
gmtofd's Avatar
Green/white wire to grd, thanks for the response.
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
