amount of freon
Car: 1984 Trans Am
Transmission: 5-speed
amount of freon
ok guys im retrofiting MY A/C since I have access to an a/c machine how much r134a and ester oil does the system require?
and yes I have a trained a/c man working with me just to get that out of the way
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Re: amount of freon
one rule of thumb is:
ambient temp (air temp in front of radiator/condeser) x 2 = min high pressure reading
ambient temp x 2 + 50 = max high pressure reading.
example:
ambient air temp = 70 degrees
x 2 = 140 = min high pressure reading
140 + 50 = 190 max high pressure reading
The oil should be about the same as the spec.
example:
tyeo098
Nov 30, 2015 06:27 PM
