Major A/C,Heating Problem!!!
Old Jul 16, 2007 | 06:49 AM
kavesman1's Avatar
Car: 1989 GTA Trans Am
Engine: 350 TPI...for now
Transmission: Stock 700R4
I need help finding a gremlins the A/C system.After a little while of running the GTA's heater,There is a burning smell and a little smoke that come from the defrost vents.it usually happens when i turn off the heater.What could it be !?! I want to find the problem before Fall/Winter comes in, or before the dash goes up in flames
Old Jul 16, 2007 | 07:04 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Major A/C,Heating Problem!!!
There might be some debris stuck in the resistor coils in the heater box. It's the ones that allows for all the less-than-full-speed operations of the fan. They are located where you see some wires plugged into a (removable) panel on the box.
Old Jul 16, 2007 | 07:30 AM
kavesman1's Avatar
Where is it located? Under the passenger side,or on top of the heater box? when i get home on the 29th this month,i'll be replacing the heater core...What fun....
Old Jul 25, 2007 | 04:52 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
On a Camaro it is located right next to the blower motor in the engine compartment. The plug will have about 4 wires going into it and there are two mounting screws that hold the coil in the blower box. When you take out the screws you will see the coils when you pull it out. You don't even have to unplug the connector on most GM cars if all you want to do is check the coils. Mine have burned out a couple of times....
Frismund Snoid
Aug 27, 2015 11:08 AM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
zeitghaist
Aug 18, 2015 07:33 AM
