overheating problem
Old Jul 20, 2007 | 08:58 PM
cityspud117's Avatar
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
overheating problem
i have a 91 z28 with the lb9 305....for some reason after ive been running the car for a while when i park it in my garage it seems wayyyyy to hottt....i even wait a few hours and its still pretty freakin hot when i chekc back on it..but i also look at the temp guage when i drive and its about right where its supposed to be it just seems really hot when i park and like i said even after its been sittin for a while it still seems hotter than it should be...is this normal or what could the problem be????thanks in advace
mike
Old Jul 20, 2007 | 10:58 PM
cheppibear's Avatar
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
Re: overheating problem
What do you mean by way to hot? The engine, radiator, hoses, inside the car?
When you shut the car down (garage or driveway) the engine stops running and therefore the cooling system stops pumping the water. While in theory the engine is not getting hotter, the heat is no longer actively dispurse via the cooling system. The engine (and coolant within the engine) has to cool down passively without any aid from the engine's cooling system.
Old Jul 21, 2007 | 08:11 AM
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
i know what your sayin but my dads mustang doesnt seem nearly as hot afters its been running just as long as mine when its parked....but the entire motor if ya put your hand up near the wipers u can feel the heat and how hot it is...and i can check it like 5 hours later and its still pretty freakin hot...same with my dads stang i can check that about 5 hours later and its cool...dont get why mine stays so hott for so long
Old Jul 23, 2007 | 03:28 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
gm made there cars run hot so it will burn more gas and emissions but that does seem pretty hot i haven't had mine on the road yet so i can't tll ya about the 5 hours thing tho.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
