problem with overheating
Old Jul 30, 2007 | 08:38 PM
LEONELB's Avatar
ok so last weekend i replaced my thermostat housing,thermostat,water pump ande the radiator got a good cleaning, then a couple days later my car started overheatin every time i use it when i check da radiator the coolant level is very low but their is no leaks anywhere
Old Jul 30, 2007 | 09:07 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: problem with overheating
Keep topping off your coolant recovery tank. If memory serves me right, `87 and up use a reverse rotation water pump with the serpentine belt. Check to make sure you got the right pump.
Old Aug 2, 2007 | 04:28 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
How is your oil looking? No coolant in it I hope? How about the passenger side floor, is it wet? Every time the car is cool, top off the radiator and bring the coolant tank up to proper level. What thermostat did you use? Are your fans working? I like to use 30% anti-freeze to 70% distilled water and 1 bottle of water wetter. Does your car have the single serpentine belt? What kind of shape is your radiator cap in?
Old Aug 6, 2007 | 12:46 AM
LEONELB's Avatar
well my oil looks good i have dual fans and both are workin properly and i have 50% anti frezze 50%water and i replaced the rad. cap a week ago and i haven't noticed the floor beig wet and yes i do have a single serpentine set up
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
