weird overheating problem
Old Aug 6, 2007 | 11:31 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
I am asking this for my step dad he has a 1989 Firebird with a 2.8 v6 and the car will overheat sporadically. somedays it will over heat before he can get down the road a mile and otherdays it will go hours with out overheating. I have racked my brain for the last few weeks trying to figure this problem out and correct it. I have check everything in the cooling system and it all seems to work fine but nothing has solved the problem.
Old Aug 8, 2007 | 04:30 PM
ND4SPD86's Avatar
Re: weird overheating problem
Bump
Old Aug 8, 2007 | 04:40 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Sounds like the thermostat may be sticking. You may want to replace it with a 180 high flow if it has been in there a long time. Summit has one I use, Part # EMP-301. You can also replace the fan switch for one that comes on at 185-200 instead of the factory 225 or so.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
