Canīt find my sensor
Old Aug 7, 2007 | 03:06 PM
Jonas_76's Avatar
Iīve been searcing everywhere for the sensor to the cooling fan on my 86 Trans Am with the 305Tpi engine. I got info from the Swedish T/A club (since iīm from there) that itīs supposed to be located between the two cylinders furtherst back on the passenger side but i cannot find it. Iīve had it up on a lift 3 times now with a friend who is a pretty good mechanic without any results. We have found every other sensor possible but that one is not there
Old Aug 7, 2007 | 03:33 PM
84z28h.o.'s Avatar
Re: Canīt find my sensor
I have an 84 Z28 H.O. but it is carbed, not the TPI. The fan sensor is on the passengers side right under the exhaust manifold, between the spark plugs. Just like the coolant sensor for the gauge on the dash is on the drivers side, right under the exhaust manifold, between the spark plugs.
Look around the oil dipstick for the fan sensor. But then again, I do not have the TPI motor.
Old Aug 7, 2007 | 05:19 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you do not have to put it on a lift . it should be on the cylinder head between #6 & #8 plug . should have a single wire going to it . wire may have came off for some reason . [ mine did ] any way thats where it is ,you should be able touch it with your fingers under the manifold .
Old Aug 8, 2007 | 01:35 AM
Jonas_76's Avatar
Ok that gives me some hope atleast. But can you change it from above?
Old Aug 8, 2007 | 05:59 AM
UNCLE TOM's Avatar
yes , i changed mine that way . just basic tools and teflon tape on new threads .
Old Aug 8, 2007 | 11:51 AM
Jonas_76's Avatar
Thanks alot. Iīll have a look when it cools down a little
9192camaro
16
Feb 3, 2019 12:21 AM
Cornholio7979
Sep 20, 2018 02:31 AM
Caspar
Jun 19, 2016 11:19 PM
Bstrang6
Sep 8, 2015 04:29 PM
