Using Temp Sensor from 1980 ok?
Old Aug 15, 2007 | 12:04 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Did a carb swap, and the heads I put in don't have provisions for the drivers side temperature sensor. So i figured instead of drilling and tapping a $500 aluminum head, I would just put the sensor in the carbd intake manifold. Well, figured out that it was too small. So I picked up a sensor from autozone for a 1980 camaro that fits, but now my temp is reading 260. I quickly parked the car and shut it off. It ran at a cool 190ish with a fan switch rigged to constantly run with the TPI, but with the carb it seems to be running hotter.
Will a sensor from 1980 send a different electronic current to the gauge and cause it to read incorrectly, or are sensors all the same? Just wanna make sure I'm not running 200* and reading 260*. Is it typical for a carb motor to run hotter than a TPI motor?
Old Aug 15, 2007 | 01:45 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: Using Temp Sensor from 1980 ok?
This doesn't really answer your question, but have you seen the probes that fit in your radiator between the fins? It may be a bit easier than fussing with electronics made for different vehicles.
Old Aug 15, 2007 | 09:09 AM
The probes? Are these inlets for the sensor? Sorry I'm not familiar with these.
Old Aug 15, 2007 | 11:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use the right sensor for your car, and a pipe bushing to put it in your manifold.
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
