cooling additives?
Old Aug 20, 2007 | 02:25 AM
mr. maro's Avatar
cooling additives?
hey guys does any1 have ne experience with cooling additives such as royal purples purple ice or dei coolant additive or anything. do these really help cool the temperature or what?
Old Aug 20, 2007 | 03:58 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: cooling additives?
yea i've used redline's water wetter. good product. it does really work. only complaint is that it looses effectiveness over time. i'll probably flush my coolant soon anyway and pick up another bottle. i've also heard that the royal purple product is pretty good too (i think they're all basically the same but don't quote me on that.)
Old Aug 20, 2007 | 05:06 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
I use redline water wetter. noticed a 15* temp drop over standard 50/50 mix. i put one bottle in with a 70/30 mix of antifreeze/coolant.
Old Aug 20, 2007 | 11:18 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I`ve used Redlines Water Wetter for awhile now and it drops the temp 5-10 in my 383 `88 Iroc. It will drop the temp a little more after changing the anti freeze to water ratio and onebad89RS said. It also works as a water pump lube.
Old Aug 26, 2007 | 09:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
well i have scoffed at many " snake oil products over the years " and have been proven wrong more times than i want to admit . [ aviation mech. since 1956 ] bottom line , if it works do it . [ damn i am old , and still a gearhead , must be like a virus , hope yall keep it as long as i have ] . 89rs , lo3 , t-5 , still like to chirp tires , and hear that downshift . [ mild mods, american thunder exhaust , and others ] . keep it going young men/ladies .
Old Aug 26, 2007 | 10:30 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Only as old as ya feel man.
Old Aug 30, 2007 | 10:11 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I tried using water wetter, but i havent noticed a difference, but it might be because i wasnt thinking straigh and put it in the reserrvoir and not directly the radiator.
Old Aug 31, 2007 | 05:27 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Camaropunk, yes it needs to go in the radiator and you should see some difference in temps. One of the reasons to use it is that you can change your anti-freeze to water ratio without having any new problems arise. I run 30% anti-freeze to 70% distilled water along with 1 bottle of water wetter which is also a water pump lube and helps prevent rust. It seems to cool my Iroc more than my `74 El Camino. One word of caution about anti-freeze that was in a post I think this last week is to use only Peak or Zerex. They are the only two anymore that do not cause electrolysis problems. Check out the post and it will explain it better than I am.
Old Aug 31, 2007 | 05:49 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I guess I will try it again then, i realized after i poured it in there i should have done directly in the radiator
Old Dec 21, 2009 | 08:51 PM
one92rs's Avatar
Car: SOLD!!!!!
nothing lubes a water pump. if coolant could lube a water pump we wouldnt need grease. water pumps run sealed bearings. sorry to bring an old thread back. but water pump lubricaters are truley snake oil.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
Fronzizzle
Sep 8, 2015 12:10 PM
