Cooling problems!!!!
Old Nov 16, 2009 | 05:32 PM
Anderson09's Avatar
I have a 1988 trans am 305 TPI. The fans Stopped working properly and it overheated and split the radiator. Will it cause computer errors if i put a manual override on the fans. Also whaqt is a recommended pressure of the radiator cap?
Old Nov 17, 2009 | 01:04 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Cooling problems!!!!
I beleave the cap is 16psi.Thats what Napa auto parts sold me for my car. So that's what I run on mine. By the way I also run a 200 degree fan switch where the 225 stock switch was and a manually switched axillary pusher fan in front of the radiator with a 180 degree thermostat .Just a few things to keep her under that 225 mark. IMO that's way to hot. Mine stays around 190.
Old Nov 17, 2009 | 09:22 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No - no computer issues with a manual switch. In fact, you can ignore the factory fan switch and install a seperate fan controller if you like - I did 'cause I never liked the factory switch. Most are fully adjustable, easy to wire, and best of all, no coolant in the face to install - they probe the radiator instead of getting installed in the head or block.
The ECM senses temps from the sensor on the water neck, or from the sensor on the driver side, and the ECM will make adjustments to engine according to the temp sensed.
Old Nov 17, 2009 | 07:56 PM
Anderson09's Avatar
Thanks for the help so far do you know where the factory temp switch is because i may try to replace it .
Old Nov 17, 2009 | 10:39 PM
Car: 1992 RS
Engine: Carbed 350
Should be on driver side head, between #6 and #8 cylinder.
Old Nov 22, 2009 | 12:39 PM
jnmaro's Avatar
Car: 92 camero rs
Engine: 305 tbi searching for 5.3
Transmission: t5 wanting a t56
Axle/Gears: b/w 9bolt
where did you find an aftermarket switch and your fan is pushing, meaning air is flowing towards the front of the car with the fan on the motor side of the radaitor?
Old Nov 22, 2009 | 12:40 PM
jnmaro's Avatar
Car: 92 camero rs
where did you find an aftermarket switch and your fan is pushing, meaning air is flowing towards the front of the car with the fan on the motor side of the radaitor? I live in phoenix were its pretty hot in slow traffic can i get an even lower degree of fan switch
Old Nov 22, 2009 | 06:55 PM
Car: 1992 RS
Engine: Carbed 350
He's saying that he has the stock puller fan on the motor side with a lower temp switch, AND he has an aftermarket pusher fan on the front side of radiator with a manual switch on it that pushes air towards the motor.
Old Nov 22, 2009 | 07:09 PM
jnmaro's Avatar
Car: 92 camero rs
thanks for the clarification
Old Dec 21, 2009 | 07:50 PM
xracer27's Avatar
The last time I looked the drivers side had cylinders 1,3,5,7!
Old Dec 21, 2009 | 09:02 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
